Fractal Design Define R6 Review
December 20, 2017 | 15:00
Tags: #atx #case #chassis #mid-tower
Companies: #fractal-design
Performance Analysis
Despite the apparently closed design, the Define R6 clearly doesn't struggle for airflow, delivering some very good temperatures on both fronts and sitting near the top of the charts. To be fair to the other cases, this is with three 140mm fans running at full speed, which did mean they were audible, although not loud.
Of course, there are so many ways you could configure this case that these results don't mean as much as they once did, but it's reassuring to know that your components will be well looked after if you're happy with the default arrangement.
Conclusion
The previous iteration of this case was decent enough, but the new Define R6 feels like a true return to form. Many of its design touches are arguably predictable (tempered glass, vertical GPU support, PSU shroud, etc.), but that doesn't make them any less appealing. The build quality has been massively improved, and the case is easy to work with at every step. The flexible interior supports multiple hardware configurations without much stress as well, and whatever you put inside is sure to look pretty great thanks to the clean design and cable management. Support for extras like the upcoming USB 3.1 Type-C front panel is good news for those who want the latest and greatest, and overall we think the price is fair given the quality. While Fractal has missed the Christmas rush by releasing so late in the year, we can easily see this being a very popular case through 2018, and for good reason.
Posted by Mr_Mistoffelees - Wed Dec 20 2017 16:45
jrs77
Replace the FOTM glass and give it back it's sounddampened side-panel.
Buy the version with the sound dampened side panel, if that's what you want.
I won't be buying one of these, only because I bought an R5 earlier this year, which I expect to be using for many years.
Posted by Anfield - Wed Dec 20 2017 16:48
jrs77
Get rid of the drive-cages alltogether in the front and shorten the case.
Some people need space for several properly cooled HDDs, homebrew NAS Cheesecake.
Posted by bawjaws - Wed Dec 20 2017 17:34
Not the cheapest, is it? The standard version in particular looks very dear.
null
